high temperature o'rings
does anyone have experience with High Temperature o'rings? I am talking fire tested rings, so will see 1300F
high temperature o'ringshigh temperature o'rings(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: high temperature o'rings
See "Challenger".
I dimly recall some removable high temperature metallic seals called "Clam Seals". I don't think they are in production anymore. The only reference I can find is a highly simplified typewriter sketch here:
ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.../19750071373_1975071373.pdf
See Figure 6(b).
They were axially stiff and sealed by Brinelling their way into the gland faces, which means they only worked once if they worked at all.
Caterpillar uses what amounts to a two-hump bellows as a gasket between their turbochargers and downstream pipes. It is axially flexible, and requires perfect faces to sort of seal at all. Mostly, it either leaks until the leaks are clogged by soot, or it burns out immediately, and is then replaced with a flat composition gasket, which fits apparently by happenstance.
Mike Halloran
Pembroke Pines, FL, USA
There are hollow torroidal metal gaskets made by some (Haskel amongst others) that some people call "metal o-rings", but these do not behave the same way as some fictitious elastomer which survives 1300 F.
There are also metal gaskets designed to be somewhat pressure-loaded, such as the seal ring used in the Grayloc connector.
as rule of thumb, I usually consider the maximum allowable temperature for o-rings made of engineered polymers around +325°C = +615°F (with reference to DuPont™ KALREZ®, for example: see http://www.kalrez.com).
In presence of oxygen, graphite faces high risks of oxydation above approx. +450°C = +840°F.
So I believe You have to switch to graphite o-rings for the temperature You mention, as well as to adopt design solutions capable to reduce temperature in the area where o-rings are assembled onboard the valve, if possible.
Hope this helps,
'NGL
_______________________
The last sentence should have been:
"So I believe You have to switch to metal o-rings for the temperature You mention..."
Thanks and Regards,
'NGL
