STAAD AISI code check for User-Defined Sections
I am trying to create custom sections in STAAD, and have tried creating User tables (general and prismatic), and changing the STAAD database tables. The shapes should be checked using the AISI code.
When I apply the shapes defined in the User Tables, the results state that the sections cannot be checked with the AISI code.
When I apply the shapes created in the database tables, I get an error stating that the table does not exist.
So the base question is, can STAAD run an AISI code check for a custom shape? And if so, what would be the best way to define the shape? I am using STAAD Pro V8i.
Any insight would be helpful. Thank you.
RE: STAAD AISI code check for User-Defined Sections
Based on the section builder website, the program will determine an equivalent section for you in order to create the code check, I was just hoping for a more direct method through STAAD.
Based on Bentley's forum (see link below), modifying the Section databases in STAAD to include the new section is a way to "trick" the program into performing the AISI code check on a custom shape, but I have been unable to get this to work.
http://com
If you still encounter problems you need to create a service ticket by going to http://www.bentley.com/serviceticketmanager/ with all details and technical support staff at Bentley will be able to assist you.
