how to set the colour of a part...
this is most likely a very easy question to answer but how do I change the colour of a part in the model space whilst in rendering mode shaded or is this something you can only do in the assembly space...?
many thanks,
James
RE: how to set the colour of a part...
CTRL+J or Edit->Object Display
Ryan Lee
Design Engineer
Constar International Inc.
The answer depends on exactly what you mean by 'rendering mode'. If you are using a simple shaded mode, then go to Edit -> Object Display; if it is a studio shaded or high quality shaded operation (HQ is really only used to output a static render for a presentation or frame for an animation), then you will have to apply a material to the body to change its appearance.
And don't confuse the settings under...
Tools -> Materials -> Assign Materials...
...with what cowski was talking about.  To find the place where making a 'material' assignment will actually change how a model is rendered, you will need to go to...
View -> Visualization -> Materials/Textures...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
got it - thanks guys...
