Extraction of drilled pile casings without a hammer.
I have a client who has asked us to write a procedure for "dry" pulling casings with a crane (i.e. no extraction hammer will be used)
His client and the crane manufacturer have their doubts, but I believe it's possible to proceduralize the process and perform the maneuver safely.
Do anyone have any experience of this process or developed any way to quantify the force needed to pull the casing?
The casing is 84" diameter and 60'-0" long.
www.hliconsulting.com
Specialists in Heavy-Lift and Transport Planning
RE: Extraction of drilled pile casings without a hammer.
Is there any particular reason why he doesn't want a hammer to be used ( Railway company ?) or is it just because he says so ?
If the pile has been installed with a vibrohammer then it is likely to be pulled out with a vibratory hammer or a casing oscillator. If it has been installed with a drop hammer, it will be very hard ( = impossible in my mind ) to pull it out.
As a heavy lift specialist, I guess you know what will happen to the boom of your crane if something fails on the line during this "dry" pull !
I suppose you could try fitting a pvc sleave liner to the inside of the casing, but still I think the force required would be large and if the pile casing did start to move could be difficult to control.
Could you jack instead using large steel plates on the ground to jack against and then take the load by the crane when it becomes free. You would need jacks with a long stroke, but even then I think the operation would just take too long.
We suggested the jacking idea to our client, and he will do that if he cannot get permission to "dry pull" This is merely a contingency in case they lose their hammer. It is not meant to be a common practice.
He says they routinely pull casings like this, and the only issue is getting started. Actually pulling the casing against un-compacted earth and wet concrete is simply a function of the crane, and can be monitored through the load indicator in the crane. The procedure calls for the LMI to be verified prior to lifting.
I wrote him a procedure that requires the weight of the casing to be doubled, and that the crane shall not exceed 85% of its rated capacity.
If the damn thing still won't move, they are required to stop, fix the hammer and use it or go and get jacks.
I think your casing will weigh around 9T, perhaps if you have a breakdown you will end up leaving the casing in.
The 275t crane is actually rated for 165,000 Lbs
I certainly will not allow them to pull that much, as a sudden release would have unpredictable consequences.
I really just trying to put a conservative, safe procedure together for something that appears to happen in the field quite frequently.
It seems I'm not going to get any professional support, so I may decline to give my opinion.
that is a much bigger crane than I typically see on a piling site. So I had a look on the internet to see if I could find anything useful. I think I did including a sample calculation, but still they don't recommend a straight pull without rotation or vibration.
ht
I pride myself on my search abilities, but I missed that one.
Thanks a lot!
