Minimum Web Lenght
Minimum Web Lenght
as the image attached, I would like to set the Minimum Web Lenght after setting the material.
In the sheet_metal_material_table I set thickness, bend radius and k-factor.
If in this file I'm not able to set the Minimum Web Lenght, exist a workaround or some type of solution to set automatically ?
It's possible ?
It's possible ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
