simulate machine code file
Hi!
I am on nx-6.0.5.
There is this option under 'simulate machine code file', under options: save as a part file.
How does it works?
I have a four-axis nc file, what runs in the simulation almost correctly.
I need the facet body, to compare different toolpaths.
When I check this option, and set directories under manufacturing preferences, it makes nothing. What is the problem?
thanks in advance
kukelyk
RE: simulate machine code file
I can't believe it.
No one used it?
Or maybe you do not understand my problem?
kukelyk
In the sample directory there is an example on how to use 'simulate machine code file' with a pdf document (nx7.5). mach\samples\nc_simulation_samples
I recommend you pose this question in the GTAC Support Forums, when many NX users, support folks, and product managers participate. You will need your webkey to log in through the support site.
http://bbs.industrysoftware.automation.siemens.com/vbulletin/
Mark Rief
Product Manager
Siemens PLM
