Rendering Problem in Creo
Howdie.
I am having a problem with rendering in Photolux with View Menu > Render Window. Please see attached image. All of the surfaces are smooth surfaces but for some reason I get the weird pattern where ever shadows occur. I have tried adjusting all of the settings in every way possible but the problem does not diminish or change in any way. It is not affected if I use maximum quality on everything. THIS ONLY HAPPENS WITH SOFT SHADOWS SET TO ANYTHING OTHER THAN ZERO. In other words, hard shadows work fine. No matter how low I set softness, the result is always the same.
I'm probably missing something really simple no doubt, but can't find it.
Many thanks!
Many thanks!
