HOW TO MODEL SLAB
HOW TO MODEL SLAB
HOW TO MODEL THE SLAB IN STAAD? PLS GIVE DIRECTIONS... THANK YOU IN ADVANCE
RE: HOW TO MODEL SLAB
You'll have to model this using a mesh of plate elements. Though that may be more basic / obvious than what you were looking for. You can then use the plate force contours and such as the basis for your reinforcement calculations.... which I'm guessing you will have to do by hand.
For step-by-step details go to Help – Application Examples - American Examples - Example Problems – 9. Modeling slabs and shear walls using finite elements. It should be noted, that STAAD.pro has an alternative method where the slab can be modeled as a surface and then automatically meshed (which is excellent for complex geometry) but if you are new to working with plates, I recommend the former.
