Grounding / Earthing Materials
Dear all
Could you please tell me the methods of earthing (i.e materials). I know about using Ground rods/pits for the same. I heard from some where about using Deep bed anode system which gives less resistance & one more system using some type of Chemicals.
Lakshmipati
Lakshmipati
RE: Grounding / Earthing Materials
What is your application? Power grid, building, communications lightning protection?
The last substation job I was on had very poor ground conductivity. The entire site was covered with about one meter of trucked in lower resistivity soil and a one hundred foot deep well was drilled at each corner of the site. The grounding electrodes were lowered into the wells and then Erico GEM was poured into the wells.
Google "erico GEM"
Bill
"Why not the best?"
Jimmy Carter
