Pipe line design
Pipe line design
Gents,
Our team is taking over one platform which is under detailed engineering phase,there is an issue that we are facing with, and I need some your advise for this issue:
Previously our design for pipe line is suitable with riser 16" wt 25.4 API 5L X60 and MAWP is 238 bar ,however we are trying to reduce MAWP of pipe line to around 120bar.
Anyone knows what is the standard for this changing? what kind of material/parameters will be selected for this pipe line? and if we are changing this pipe line, can we perform pigging with this riser?
thanks for your advise.
RE: Pipe line design
David
Thanks for your advise,the problem here is I have not found the company's file yet.
Could you please provide some more information for this issue?
Give us enough information to help and you might get some help.
David
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
Mr Biginch is correct, I am in Jakarta indonesia now.
We are approaching company's file now ,so will collect more information in this.
Will get back to you soon.
Thanks.
I just got some more information and need your help.
Our riser is 16" and WT is 25,4mm and the pipe line is 16" and wt 10,3mm.We are choosing the scraper pig for pigging this pipe line,do you have any document or standard to explain the selection of pigging?
