Thickening a surface is causing me issues
See attached file. How do I make the "ANNOYING" feature thicken?
I'm assuming the issue is because I have a super small curvature issue at the southern most point when I run a check. If that is the issue, how do I fix it?
RE: Thickening a surface is causing me issues
Dan
www.eltronresearch.com
Dan's Blog
