Piping Design Centrifugal Pump
Why the suction and discharge lines have to be one or two sizes larger than the pump connection nozzles? What could happen if the suction or discharge lines are larger than the pump suction or pump discharge nozzles? I would appreciate if anyone can help me with an answer to this topic.
One Point
RE: Piping Design Centrifugal Pump
This subject has been discussed at length please check the "Search" feature and see what you get.
Hi Pennpiper,
I could not find any answer to my questions. If you know of a link where I can read about this topic, please send it to me.
One Point
It's probably because you're not looking in the pump forum (forum407).  Here's a few to get you started:
thread407-251629: Low capacity Diaphragm pump - sizing suction and discharge
thread407-231947: Pump suction pipeline size less than pump suction nozzle
thread407-262097: Pumps suction and discharge lines
thread378-239699: Question about the piping at pumb suction line
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
For the suction line, you need to look at the difference between NPSHA and NPSHR.  The following link should help:
http://www.mcnallyinstitute.com/11-html/11-12.html
For the discharge, you need to look at the pump curve and the system curve and their intersection to understand what you need.
Your questions sound like they are from a piping design training class.
I think you need to check your text book and your notes then ask your instructor.
