Sketch thickness or more contrast
it's possible to increase sketch entities thickness for more comprehensive visualization ?
I attach an image to better understand.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Sketch thickness or more contrast
First you can go to...
Preferences -> Object...
...and set the Width for all the various curves Types (Lines, Arc, Conic, Spline) to 'Thick Width' (note that this will only effect new curves being created). Of course, before you will actually see the 'Width' of the curves you will need to go to...
Preferences -> Visualization -> Line
...and toggle ON the 'Show Widths' option. You should also toggle ON the 'Wireframe Contrast' option as well. Another thing that can help is to go to...
Preferences -> Visualization -> Visual
...and toggle ON the 'Line Antialiasing' option as this will also improve the visibility of curves.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thank you...
