Setting for big assembly
which are the best visualization setting for big assembly ?
can I save a file which this setting that can be reused as desired when I work which big assembly ?
For example I saved a visualization template.
Can I save a visualization template or something similar to use with a double click that apply my best performance setting without to go every time to the relative setting ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
