ANSYS WB 11 MESH CONTROL
Hi everyone,
I am quit new to Ansys, I have to make structural analysis with Ansys WB. Is there a way to get mech controls such as element type, number od nodes of each element etc... in a similar way you do with Ansys Classic?
thanks everyone in giving me an answer!
RE: ANSYS WB 11 MESH CONTROL
I have to say, if you have the opportunity to upgrade, Ansys WB 13 is leaps and bounds better than Ansys WB 11 when it comes to meshing. Ansys Classic can mesh pretty much anything under the sun with enough effort.
In Workbench, you can control element size, meshing method, and so forth by inserting mesh controls. You'll likely have to slice up the model in DesignModeler and create multibody parts (Freeze Bodies>Use "Slice">Select Parts>Right Click>Create New Part).
It takes a bit of a knack. People who'd been using Classic for a while found WB11 pretty frustrating; if you're good with Classic it seems crippled. Still, it's not bad, and it can get you to an acceptable mesh.
Again, Ansys WB 13 has far better meshing tools, and the ability to mesh bits of the model at a time, rather than asking the mesher to figure out the whole thing. It's worth the upgrade. If you can't upgrade, and WB isn't getting you the mesh you want, try flipping over to Classic.
can I make a mesh in classic and then import the mesh in WB to make the other pre process phases?
However, importing a model from DesignModeler into Classic can be very handy. DesignModeler has a lot of great tools for cutting up and defeaturing geometries. To be clear, the learning curve for meshing in Classic is steeper, but you have more control.
