INSERT SEVERAL SCREW SELECTING JUST A POINT SKETCH MOLDWIZARD
I have to apply more than 150 screw between 2 solid body, and I need to be abble to make adjustment on their location after i use the screws (available form standard part mold wizard).
I first created a sketch with all the point I need.
then i need to select each point location one by one using moldwizard screw ...
Clearly there must be a way to select all the point in the sketch all at once???
I apreciate a good tip on that one because i realy dont want to select 150 points one by one.
thanks guys
thanks guys
RE: INSERT SEVERAL SCREW SELECTING JUST A POINT SKETCH MOLDWIZARD
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I´m talkink about the way Moldwizard works:
For exemple I'am able to create a sketch with 100 point on it, and open 100 thread just by selecting the sketch feature (hole command in modeling).
What i need is to select several point all at once so that moldwizard insert the several standart part just with one selection (of a point sketch)
thanks John.
John R. Baker, P.E.
Industry Sector
Cypress, CA
