"Execute" Command Missing Under "File"...
On one of our engineer's NX7.5 graphic's windows, the "Execute" command is missing under the "Utilities" command. Is it possible to have this not showing?
RE: "Execute" Command Missing Under "File"...
Depending on the 'role' you have activated, commands may or may not appear. Try switching to a role with 'full menus'. A word of warning: you may lose some or all of your toolbar layout. If this is unacceptable, you can customize the role you are in to add the commands you need.
Thanks cowski, that is just what it was.
