Axial Static vs Dynamic Test (PDA)
Which is more reliable, Axial Static or PDA? What is the pros and cons of these tests?
Structech08
Structech08
RE: Axial Static vs Dynamic Test (PDA)
f-d
¡papá gordo ain't no madre flaca!
Thank you for your input.
structech08
PDAs do have some disadvantages such as do not work with vibratory hammers (unless hokus pokus is invoked). Probably not well suited for timber, composite or drilled piles. They do have the advantage providing some indication of side friction vs end bearing.
