Proper Protocol for Cad Request
I was wondering what you guys do when you need to request cad files? Do you put this in the GC's lap or do you call the architect direct? What is the *proper* route for this request?
RE: Proper Protocol for Cad Request
Rafiq Bulsara
http://www.srengineersct.com
If that's the case, I usually dump it on whomever we're subbed to, be it the plumber/tin basher or general contractor. They usually have a bit more weight to throw, and since I always write it into our standard bid letter that we require electronic files, they usually take care of business pretty quickly.
Of course, this is all on the assumption that you're a sprinkler designer looking for floor plans to lay out your system.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
