Convert to Sheet Metal
I've a part created in the modeling environment.
I need to convert to sheet metal, but I'm not able.
The part is an old part and not made by me.
Solutions /ideas ?
Solutions /ideas ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Convert to Sheet Metal
Another way (if you want to get flat pattern) is forming/flattening tools (these tools are available if you have advanced sheet metal license).
I tried to "extracting external surface of your part, then thicken it (you will get new solid which will be approximate to your original part). Then you will be able to convert it to sheet metal.", but doesn't work.
Are you able ?
Thank you...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
thanks for spending time, but I resolved recreating the part from zero.
This is another sample of what a CAD user can create bad modeling part.
This CAD user works with UG from a lot of time.
This is an example which the setting that I would uncheck will be helpful.
Thank you...
