Gas Cut Water
Gas Cut Water
Gas Cut Water
Hi all,
I was wondering, when considering a vessel in the north sea, how much gas would it take to sink a boat?
What would be the calculation method to work out when the water would have sufficient gas cut as to cause the boat to loose buoyancy?
R
RE: Gas Cut Water
Are talking about gas leaking into the ocean under a vessel causing it to sink?
RE: Gas Cut Water
yeah I am unsure how to approach the calculation. I know the gas in the water will cause the density to decrease which will mean the weight of water displaced is less than the weight of the vessel which will cause it to sink.
I know it is a play on archemedies but unsure what to do.
RE: Gas Cut Water
The point at which the vessel sinks is when it reaches zero bouyancy. This depends on the weight of fluid displaced by the weight of the vessel. Say the vessel displaces 1/2 of it's total volume normally in water. If the gas cut were to reduce the effective density of the water/gas to 1/2 of the original density the vessel would displace its entire volume of the water/gas mix. Therefor causing it to likely sink.
