Material table
Material table
Material table
someone use personalized material table located in sheet_metal_material_table.txt ?
We produce lot of sheet metal part and I would automatize the process to calculate the correct flat-pattern.
At the moment we put manually the k-factor, but maybe an useful table improve and reduce errors.
Can someone link some yours files ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
