Preventing the Deletion of Child Features
reading some presentation I've found this option.
I think this it's very useful if unchecked.
Someone use this setting unchecked ?
During the lecture I read this :
"When this check box is cleared and a parent feature is deleted, the Edit during Update dialog will appear for each child and allow you to explicitly accept, delete, blank, or edit (reattach) it.", but this is not true or I wrong something ?
The tooltip doesn't explain about a dialog.
Anyway I would like to promote to my colleague.
If someone didn't like it, can this option be set at the user level ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Preventing the Deletion of Child Features
I suspect that the presentation is a bit out-of-date.  Did the author indicate which version of NX it was that he was referring to in his presentation?
You see we removed the 'Edit During Update' scheme a few releases back.  What happens now is if the child feature(s) cannot automatically update once its parent has been deleted, it will be placed in a state similar to being suppressed except being tagged as 'out-of-date'.  If you later create some other feature(s) which allows this existing feature to update it will automatically be made active once more and applied to the model.  Or you can edit it (by selecting it from the Part Navigator) and then you will have the opportunity to select new face/edge/curve/whatever reference so that it can once again be made active and usable.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thank you John,
what about my last question ?
Setting at the user level in customer default ? Possible ?
Thank you...
- How come your User level settings are Read only ?
 The "normal" fashion is that "Site" settings are read only to everybody except the sysmanager and that he/she locks options away from the user level settings. Then all remaining user level settings are free to change.
So the response to your second question is yes, possible, if the read only is ...
NOT if you don't have READ access to YOUR .dpv files or if your system admin decides to lock Customer Default settings at his level.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Sorry, I meant READ/WRITE access to YOUR .dpv file.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Sorry John,
what I need to say to CAD manager to create a user dpv for only this option ?
Thank you...
If it were me I would demand that your system manager NOT mess with USER options (we didn't call them 'User' for nothing) and to give you full access to you Customer Default file and to ONLY lock those items (if any) at the 'Site' level which are truly the options that should never be changed (if you think about it, this list will almost certainly be very short).  If you people just install the system as it's intended, it will work as you need it to.  It appears to be that it's the messing around by them that's making your life more complicated, not necessarily the software itself.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Hi John,
but I don't understand your English, it's clear that it's a my problem, but using Google Translate give me a bad translation.
What I can understand it's 'Avoid to manipulate Customer Default' ?
I think it's true, but this unchecked option it's very useful as mentioned in the presentation, but I would like to be an user setting.
Others CAD have this options on deleting (SolidWorks an Pro/E).
If I want delete a feature for different reason, why I need to lose time to avoid child deleting ?
Whit this option I delete and then I re-link what miss, as in assembly mating.
Thank you...
Now I don't know what it is that you're looking for.
Can you or can you not change this setting in Customer Defaults?  If you can, does it give you the behavior that I described or not?  If your complaint is about the fact that we no longer are using the 'Edit During Update' mechanism, then there's not much that we can do since this approach is no longer being used and it will not be resurrected.  The problem was that it halted update and forced the user to immediately try and fix the problem.  The current approach allows the model to update as best that it can but to the very end so that you at least have a valid model.  At that point you can decide what it is that you may wish to try to resolve the problem or perhaps to just ignore it or perhaps even delete the out-of-date features and try something else.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John,
I can change the customer default, but it's a CAD Manager job that usually ask to some experts users if it can be changed.
Some experts CAD users are users that use NX from V16 and model whit the same feature and method present in UG V16.
My passion is the CAD and I like to discover always the best approach, new feature a new solutions.
For example, all expert CAD user use block, cylinder, pad, pocket, etc...
I didn't like those and I use sketch.
This is only a little example of what is considered the guru in NX in our company.
So I'm not a real decisional, but if the option can be an user setting, then the CAD Manager can accept because I oblige all CAD user to use this setting.
For the rest I like the improvement made in NX on 'Edit During Update' mechanism, but this option permit me to delete bad feature made from bad users, create new and best feature and re-link blends, holes, etc..whit tranquility.
Thank you...
Sorry...I wrote wrong...
"....then the CAD Manager can accept because I DIDN'T oblige all CAD user to use this setting."
Thank you...
Quote (JohnRBaker (11 May 11 3:52)):
In what version was it removed? I'm currently on NX6 and I'm still using it. I prefer to have at least a warning pop up if something goes wrong rather than having to scroll through the potentially long feature list looking for red X's. I have had to fix many files where others either didn't notice or didn't care about the red X's.
This was changed in NX 7.0 (there's an entry in the What's New document titled 'Error during update enhancements' which covers the changes implemented).
As for what your new options are, there is a Modeling Preference/Customer Default which will allow update to either run to completion with the failed feature(s) suppressed and flagged (this it the OOTB default) or to have the update halt and the failed feature set to be the 'Current Feature' thus allowing you to examine, edit, delete, suppress or whatever, similar to before, but not using an special dialogs, simply placing the system in a state where you can choose whatever action you would like to do next.
Also, irrespective of what the Modeling Preference/Customer Default is set to, the listing window will open with an explanation of what happened, but this will not halt the update, it's simply there to provide feedback and as a indication that something did fail to update as expected.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks for the info. I'm glad to hear there is still an option to stop the update and make the failed feature 'current'. It is also good that the listing window comes up, but personally, I'd like to see something a bit stronger. I've seen coworkers who have the information window off screen (usually unintentionally due to a laptop docking/dual monitor setup) or who just close it out without regard to why it opened. I think the listing window is generally regarded as a way to convey information you may or may not be interested in rather than warnings that must be read.
Well, since the whole idea was to provide an option where Update was NOT halted, the listing window was a convenient scheme to provide feedback which did not require the user to stop and acknowledge it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
