H2S Removal by aeration
I am trying to calculate how much air I should feed to remove hydrogen sulfide. Will air alone, without mixed liquor, work to release the H2S? How do I calculate the amount of air required?
I appreciate any help!
RE: H2S Removal by aeration
http://www.eng-tips.com/viewthread.cfm?qid=252943
http://www.eng-tips.com/viewthread.cfm?qid=218491
Your post mentions mixed liquor. That is a term normally associated with wastewater treatment.
This is for wastewater treatment. I figure I am in the wrong activity.
Thank you!
I did some work at a tannery that uses sodium sulfide as part of the tanning process. The sulfide is instantly oxidized to sulfate in the activated sludge process. The activated sludge process has an inherently large capcity to make the conversion to sulfate.
This can be proven by measurement of the sulfide in the effluent.
