What's the 'best' and 'proper' way...
to demonstrate another configuration of a component in an assembly?
Say I've got one configuration, with a component oriented one way, and another configuration with the same component oriented in the opposite direction.
different configurations of the component, or different configurations of the assembly. Does it even matter?
RE: What's the 'best' and 'proper' way...
If the part is the same and all you need is different positions, do it all at the assembly level.
Dan
www.eltronresearch.com
Dan's Blog
