Drawing View Problem
I am creating a drawing using a clip that was
made using the sheet metal function. I placed a
few views of this clip on the drawing. I now need
a view of the clip flattened. Of course when I
do this all of the other views are shown flat. How
do I just show one view flat without affecting other
views? Thanks in advance.
RE: Drawing View Problem
This will create a configuration in your model automatically. The configuration will have a name with FLAT-PATTERN in it.
The end result is a formed configuration (Default) and a flat pattern configuration.
-Dustin
Professional Engineer
Pretty good with SolidWorks
However when I select Insert, I cannot locate
View, just drawing view. What am I doing wrong?
Do I create a view first?
Thanks again
What version are you using?
-Dustin
I am using 2011 professional version.
I will try again.
Maybe it is done another way on this version?
From the drawing:
Insert> Drawing View> Model>
Select the model in the "Model View" pane on the left side of the screen. Hit the "next" arrow in the pane.
Within the orientation tab of the Model View pane, under "More Views" select Flat Pattern.
See attached image
-Dustin
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
-Dustin
