Just curious-Transmission question
This morning while stuck on the freeway in Los Angeles, I looked up and noted an item I've seen for a long time and could never figure out it's purpose.  Hopefully one of you transmission experts can explain this curious structure.
Well structure isn't quite right, ...On some transmission lines, looks to be something over 110 kV, but I've seen them an multiple voltages-are a series of what appear to be inflated bladders on what seem to be high tension guy wires at the top of transmission line structures spans.  They appear between a couple of structures, but not on adjacent spans, then they may appear again after several spans.  What are these "balloons"?
Just another piece of useless knowledge I can't be without.
Thank you,
EEJaime
RE: Just curious-Transmission question
Aircraft warnings
Jghrist,
Well I do feel silly, that should have been intuitively obvious.  I knew it had to be something simple.
Have a good day.
Eejaime
http://www.tanawiremarker.com/
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
