BC's Acceleration Ansys Workbench
I have a structure which is attached to slings (4 slings). The structure is then lifted through the slings. I apply an acceleration on the structure upwards in Ansys Workbench but I am not sure about the boundary conditions. Should the lifting holes ( all 4 of them ) be set to fixed support or just locked in the vertical direction ( same direction as the slings) ?
Thank you
Thank you
RE: BC's Acceleration Ansys Workbench
