Dimension Radius or Diameter?
In the drafting side, I have a cylindrical part. When dimensioning it, the dim is showing a radius. How do I change this to a diameter?
RE: Dimension Radius or Diameter?
In the first case you need to redefine the part section.
In the second case you just need to double click the circle before placing the dimension.
I was conducting your second case. I knew it was some little trick, but didn't recall what it was.
Thanks for the info.
For 2D cross sections for edit revolve you can select...
Centerline, Entity, Centerline
or
Entity, Centerline, Entity
to get Diameter Dim
Michael
