Tempering + quenching
Hola
If I was native English speaker, I for sure wouldn't need to open this topic. Actually I have simple question. I search for engineering term. The one that is meant as process of thermal/heat treatment and according to google, which I believe is for sure correct, the description of this term is:
"Tempering plus quenching"
What is this? Its well-known process, everyone knows it and so do I but unfortunately just in my native language. I search for correct engineering english term.
The process name that I search for is different than tempering, carbonitriding and cementation. But they are all (including that one for which Im asking) thermal/heat processes.
I haven't found the full list of thermal/heat processes so I cannot find it myself.
I know the question might be a bit funny, and the process whos term I search might even be the most known process of all in thermal/heat processes but I checked my dictionaries and cannot find the correct english term for it.
For sure its not "annealing" or "hardening", neither just "quenching".
To be even more specific which term do I need; Im asking for the process which is (probably) combination of quenching (=annealing?) and tempering. The process is used for steels who usually have between 0,3 and 0,6% of carbon. Hardness of material is increased because of containing steady carbides and ductility is increased.
Also; Did I say correctly, its "cementation" and not "cementing", right?
Looks like I will need to search for a better dictionary.
RE: Tempering + quenching
quench hardened and tempered
59 + 4 HRC
Here is a link to EN 10052 where you can see the exact definitions:
http://www.tubular.in/files/EN/EN%2010052.pdf
Of course quench hardening / quenching and tempering / austempering (?) is different process compering to tempering.
