Measure angle continues to display
When I use the measure angle command out of the utility menu, the results are displayed in a small window along with lines. They then dont turn off after the command is complete.How do I turn this off. I'm not taking about the information window...thx
RE: Measure angle continues to display
In the measure angle dialog box, expand the 'results display' section and change the annotation from 'show dimension' to 'none'. If you have dialog memory enabled, take a measurement with this option set and press OK. Otherwise, if you just change the option and cancel out of the dialog, the option will revert to 'show dimension' the next time you use it.
If you refresh (F5) the display, the results that you currently have on screen should disappear.
Thanks...the f5 key is what I was looking for
