DYRESM Model Help
DYRESM Model Help
Hi All,
I am using the DYRESM Model to predict the water temperature in a river section which has dam in upstream and downstream. I want to output the temperature in hourly format. I don't know whether it is possible to do or not. I encounter several problems such as Tsurf>1 , maximum layers exceeded something like that. WOuld anyone give me some better tips or the example model which has hourly output temperatures. ANother thing I don't understand is the profiles after I load the simulated model in the Arms lite. Is that the location of the upstream or downstream ?
Thanks a ton.
Jd
Thanks a ton.
Jd
