pressure and flow in fluid a branch?
I have a pipe that divides into more than one non-identical branch. I am interested in solving the pressure and flow rate inside each of the branch. Thanks
RE: pressure and flow in fluid a branch?
forgot to add: incompressible flow.
brashear - this has been discussed here many times - try the search function under the "Forums" tab on the top right of the page.
Katmar Software - Engineering & Risk Analysis Software
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
Go find a Crane's Flow of Fluids -- or buy one, they're not that expensive.
Do a flow diagram showing what size pipes, what fittings, valves, etc.
Remember that for reasonably incompressible flow what goes in at the start needs to come out somewhere.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
at branch and converging points all pressures are equal. Use this for solving the flow equastions
Best regards
Morten
where C is the orifice flow coefficient
also should be divided by 2 not multiplied...
I wouldnt ignore elevation (unless its a closed system).
Best regards
Morten
I don't think it would be pipe safe to ignore elevation in a closed system.  Elevation increases pipe pressures .. even (or especially) when there is no flow.
Let your acquaintances be many, but your advisors one in a thousand'  ...  Book of Ecclesiasticus
is this something college class homework?
no, I'm trying to model something. Yes, I can ignore elevation, because the whole thing is only a few millimeters tall. ;)
