Plotting from UG NX on Windows 7
Am I the only goober who can't get UG NX to plot on Windows 7? I have an HP430. I can plot to it with Adobe and E-Drawings, but not NX. It goes thru all the motions, but the job never leaves the "queued jobs". Here is the log file.
9 May, 2011 19:07:25:BPS: SUBMIT_TIME
9 May, 2011 19:07:25:BPS: Job 0 Submitted
9 May, 2011 19:07:25:BPS: Sending bSec ...
9 May, 2011 19:07:25:BPS: Sending bPrintTo ...
9 May, 2011 19:07:25:BPS: Sending myModel ...
9 May, 2011 19:07:25:BPS: Sending myPlotter ...
9 May, 2011 19:07:25:BPS: Sending myProfile ...
9 May, 2011 19:07:25:BPS: Sending C:\Users\Chuck\AppData\Local\Temp\Chuck_31162_d30_sh1.cgm ...
9 May, 2011 19:07:25:BPS: QUEUE_TIME
9 May, 2011 19:07:25:BPS: Job Ready to Run
9 May, 2011 19:08:10:BPS: Downloading logfile.txt ...
I don't know enough to tell if this is correct or not.
Chuck
Chuck
RE: Plotting from UG NX on Windows 7
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
On 64bit systems (Vista & Win 7), the two variables UGII_SDI_BPS_JOBS_DIR & UGII_SDI_OVERRIDE_HOME need to be set.
When they are unspecified they are created in the users profile, but Win 7 & Vista works their permissions differently from WinXP.
Creating those two variables & then pointing them to look at a folder, (c:\temp is the example I would follow) fixes the problem.
Simplest way to create the variables is:
Windows Control Panel -> System -> Advanced (TAB) -> Environment Variables (button)
Add a system variable and then enter the variable name & variable value
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5, Beta NX8.0.0.15
Thanks everybody.
Thanks to all for replying. Special thanks to Anthony for the resolving the issue.
John B.
Anthony Galante
Any ideas?
Thanks in advance.
..garry..
