AVR Valve in Slurry Pipe
Do anybody knows an Air-Vacuum Relief Valve that can work in a slurry pipe?
We have a 8"ø HDPE Pipe, with 450 gpm of slurry 45%-50% solids.
Pipe trajectory has being carefully traced, so we only have one high point, and no low points, and pumps motors have a VFD.
I belive we don't need an AVR Valve. beside, as it is slurry a regular AVR valve will be useless after few minutes of operation.
However, client insist.
RE: AVR Valve in Slurry Pipe
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
The danger is that the slurry will cake on the float. Then the AVR does not work.
AVR's are a device that the water industry oves but you dont see them in the petrochem, oil and gas, mining, power industries.
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
