Analysis of loads for nozzles in API 650 tanks
All formulas described in API 650 appendix P are based on the following document: Analysis of Loads for Nozzles in API 650 Tanks, M. Lengsfeld,... Paper PVP-Vol 430, ASME, New York, 2001.
I want to buy a copy of this document.  Where can I find it?
Hcjulien
RE: Analysis of loads for nozzles in API 650 tanks
I would recommend that you contact ASME directly - 1-800-843-2763.  They don't seem to have this volume on their website.  Or, you could try to contact Linda Hall.
Linda Hall library in Kansas City should be your "go to" resource for any obsucre engineering publication, including trade journals.  They are comprehensive, fast, accurate, and reasonable priced.
