Purlins
Purlins
I'm interested in the system of purlins/side rails and ancillary items like stays & braces. where can I get info from.
Most manufacturers only give their sizes/loadings but don't say why or where you would use them.
For example - why are the short braces from a purlin to a beam compression flange used, is it to stop the beam rotating or is it to support the purlin. If it's to stop the beam rotating does the point of attachment count as one end of the length for calculating twist?
Cheers
Mick
Cheers
Mick
RE: Purlins
Dave
RE: Purlins
dpcoon covers the details more than adequately.
