Deflection of uniform plates during vibration
Which rectangular plate would have higher delection for a G force: a plate free on four sides and a plate simply supported on four sides? I know the resonant frequency is higher in case of simply supported plate. So the deflection would be smaller in simply supported plate because deflection=(9.8*G)/(f^(3/2)) where f is the resonant frequency. If this is the answer, then why do people always try to keep the plates free instead of supporting or fixing in their design?
Thank you.
Thank you.
RE: Deflection of uniform plates during vibration
