WCS (handle) size in NX7.5
Hi All,
Can anyone tell me if and where I can change the size of the wcs icon in the modelling display? And also, the size of the wcs handles (after double click for wcs dynamics). I have two workstations, and on one workstation the icon/handles are very small.I checked all settings and to me they seem to be the same on both workstations.
I searched everywhere, this forum, settings, nx help, preferences, but can't find it.
Thanks in advance
Thanks in advance
Older budweiser
RE: WCS (handle) size in NX7.5
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5, Beta NX8.0.0.15
BTW, Tony is correct in that using the 'calibrate' dialog in Preferences is the proper place to adjust the size of these on-screen, non-geometric objects, but if you're running Windows 7 and you select the 'Reset to System Defaults' button on this dialog the display will be set to almost exactly HALF the scale that it was designed to be set to. To overcome this problem you will need to manually adjust the apparent size of the 'circle' to be approximately 2 Inches or 5 Centimeters.
Note that this issue has been resolved (we changed our code) so that if you're running NX on Windows 7 you will get the proper sized display. This fix will be in the NX 7.5.4.x release as well as the next full release of NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
@John: Indeed, the problem workstation is running win7 64 bit, the good one is XP 32 bit....
The relative datum csys size can also be changed in the csys dialog
(default is 20 I think, rather big).
Older budweiser
