Generating a solid volume of a propeller for CFD ?
I downloaded a solid works file of a propeller from (http://grabcad.com/library/xoar-21x8-propeller)to try to mesh in Gambit for a cfd project (due to the many sharp angles meshing was proving quite difficult). I initially just imported it into gambit as a parasolid as is and tried different clean up tools, but to no avail. So, now I am trying to obtain just an solid volume version of the prop in solidworks to export. I have tried knitting all the surfaces, but am having issues with the fill option. The make solid option is not available in the insert/boss menu, so I know something's up.
Let me know if anyone has any suggestions,
RE: Generating a solid volume of a propeller for CFD ?
James Spisich
Design Engineer, CSWP
Dan
www.eltronresearch.com
Dan's Blog
