Displaying Viscosity vs. Temp
I am running a simulation of a viscoelastic material with TRS behavior in Abaqus standard. I am starting to think that the calculated viscosity vs. temperature is not correct so I want to check it at some (any) interval. Does anyone know if there is an 'easy' way to have Abaqus output the viscosity, at a single node is OK?
I know that I can do this using a UTRS, or something similar, but I am hoping that I am missing an easier way.
Dan
