problem with feature driven patterns.
I have an assembly that has a sub assembly inserted then that sub assembly is patterned using a "feature driven pattern", the feature is an existing pattern from a different top level part in the assembly.
The issue I am having is that the original seed assembly for this pattern has "exclude from bill of materials" selected. The patterned parts do not keep this selection and show up on the Bill of Materials. I then have to go into the feature tree of the assembly and edit the properties of each patterned part and select "Exclude from Bill of Materials".
So... have I missed a step or just an issue with the way SolidWorks handles this?
SW 2011 SP 3.0 x64
16 Meg, Quadro 4000
DUAL DISPLAY
Windows 7 PRO x64
RE: problem with feature driven patterns.
However, the Exclude from bill of materials option can be applied en masse to the parts within the pattern. (Shift select first and last).
SW 2011 SP 3.0 x64
16 Meg, Quadro 4000
DUAL DISPLAY
Windows 7 PRO x64
Some times info comes a little quicker here.
SW 2011 SP 3.0 x64
16 Meg, Quadro 4000
DUAL DISPLAY
Windows 7 PRO x64
