HELP! IN ABAQUS
HELP! IN ABAQUS
HELP! IN ABAQUS
Can any one provide help with these warnings:
-WHERE TO FIND THE *NORMAL OPTION
EVENTHOUGH, I REFINED THE MESH BUT THE WARNING STILL EXISTS?!!!!
 ***WARNING: Abaqus WILL NOT ADJUST THE SURFACE NORMAL FOR THE SYMMETRY PLANE
             AT NODE 54 INSTANCE CON OF SURFACE ASSEMBLY_ALLCONSURF. THE
             MESH MAY BE VERY COARSE OR THE SURFACE MAY BE UNTRIMMED AT THE
             SYMMETRY PLANE. PLEASE USE THE *NORMAL OPTION TO SPECIFY THE
             PROPER SURFACE NORMAL.
 ***WARNING: 2 nodes may have incorrect normal definitions. The nodes have been
             identified in node set WarnNodeIncorrectNormal.
