Tolerances & Surface Conditions for Concrete Elements
Hi all!
Any idea where I can find guides for Tolerances & Surface Conditions for Concrete Elements? I have checked with ACI 117
but I can't really find all the things I need.
I. Tolerances
A. Flections
a. Walls (vertical & horizontal)
b. Slabs
c. Columns
B. Thickness
a. Walls
b. Slabs
c. Columns
b. Beams
C. Angles
a. Wall to Wall (Horizontal)
b. Column Corners/Beam Corners
c. Wall-Slab (Vertical)
D. Alignments
a. Local Alignment Deviation
b. Global Alignment Deviation
II. Surface Conditions
A. Honeycombs
a. Depth
b. Size
c. Area
B. Air Bubbles
a. Depth
b. Size
c. Area
C. Local Flatness
a. Depth
b. Size
c. Area
D. Stain & Discoloration
Among the list, I only get to find D. Alignments in ACI 117.
I hope you can help. Thank you very much...
I. Tolerances
A. Flections
b. Slabs
c. Columns
B. Thickness
a. Walls
b. Slabs
c. Columns
b. Beams
C. Angles
D. Alignments
A. Honeycombs
a. Depth
b. Size
c. Area
B. Air Bubbles
a. Depth
b. Size
c. Area
C. Local Flatness
a. Depth
b. Size
c. Area
RE: Tolerances & Surface Conditions for Concrete Elements
Put the tolerances you want in your specification. Codes, standards, and recommended practices can't accommodate all conditions...that's why you, as the designer, must supplement with your own.
