Manually Edited BOM Values Disappearing
Hi there!
I'm having trouble with some of the manually edited cell values disappearing in my Indented Bill of Materials. I can edit the cells, but as soon as I click off, arrow over, or hit 'enter' the inserted value disappears/ doesn't show. Is there a specific reason this is happening? It's in the item number column that is not property driven or linked. The top level assembly item numbers that ARE linked to balloons can be edited with out a problem. The odd thing is that it doesn't happen every time I insert a BOM into a drawing. Sometimes all I need to do it delete and reinsert the BOM, but for a 70+ item BOM (like the one I'm working on now), I would rather not delete all of the manual edits I have done. If anyone has similar issues or some insight on this matter, I would greatly appreciate assistance.
RE: Manually Edited BOM Values Disappearing
Why are you manually editing the item number column in the first place? What do you need to do that won't work with the options they give you?
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
