Acceptable deflection of a 25mm solid steel shaft
I've calculated the deflection of a 25mm shaft to be 2.2mm. Is this too much or is it acceptable?
Fairly basic question I know but it's been a long day!
RE: Acceptable deflection of a 25mm solid steel shaft
In what context?
How long of a shaft?
What cross section?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Circular cross section, solid, and made of stainless steel, with a length 1161.2mm.
It's supporting a bowl of liquid that will be filled up and then emptied a dozen times a day.
I would look at the stress in the shaft and then consider the fatigue as the shaft is loaded and unloaded.
Try to get the stres i the shaft below half its tensile strength if possible,then fatigue might not be such a problem.
desertfox
Why does deflection matter to you?
- Your shaft ought to not break, hence desertfox's remarks, above.
- You have an alignment issue with your bowl of liquid. This will dictate what your acceptable deflection is. You don't need to ask us.
- Your liquid and container have a mass. Your bar has a spring rate. ω=sqrt(k/m). Your container full of liquid will bounce up and down and rotate at resonant frequency when it is bumped, or emptied and filled.
Do you really need to cantilever the thing? I crudely figure that tension/compression structures are around three orders of magnitude stiffer than cantilevers.RE: Acceptable deflection of a 25mm solid steel shaft
Stress, on the other hand, is how you determine whether your part will break. For parts under a static load, permanent deflection (yielding) is often the criteria for failure. For parts under a repeated load, the maximum stress is determined by the endurance limit of the material or a fatigue life analysis (cycles to failure).
