Common Mode Voltage from a PWM drive question
I read the comment in an article "common-mode voltage arising from the non-sinusoidal current produced by an inverter's power-switching circuitry.".
This doesn't make sense to me. It's the current that produces the common mode voltage? I thought it was the inverter switching the voltage on and off that produced the common mode voltage.
RE: Common Mode Voltage from a PWM drive question
Usually motor providers ask to use a filter to limit this.
Also using suitable special ferrite-kind rings for the 3-phase output limit this problem.
But common mode voltage wouldn't be a problem on it's own. Unfortunately you can never avoid the parasitic capacitances and hence you will also see common mode currents flowing.
A sinewave filter intended to get sinusoidal currents will also adress this topic, but at a big penalty in cost and efficiency. Common mode issues can be adressed by much more simple filters.
Gunnar Englund
www.gke.org
That's a very nice explanation - thanks for sharing.
dpc
David Castor
www.cvoes.com
Thanks for all the help!!!
