NX 7.5 (64 bit) bolt circles keep going out of date on threaded holes
When using a bolt cicle in drafting on threaded holes made by the hole feature, they constantly go out of date...even without changing the feature. I have tried different things such as ensuring I'm not picking the threads etc.... but it never fails when I do any changes in the model not even related to the threaded holes it goes out of date. Then its a pain to re-associate the bolt circle because you have to remove the points and put them back in, so I have been just deleting them and waiting to the end to put them back in. Any tips, hints tricks??
Loren
Loren
RE: NX 7.5 (64 bit) bolt circles keep going out of date on threaded holes
http://www
Update to the latest qrm and you are good to go.
Older budweiser
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5, Beta NX8.0.0.15
~Loren
So in the end 7.5.3.3 did not resolve this issue but when it happens try to undo the last view(s) update and see what happens.
The IR has been closed as per the following:
This behavior is working as designed. When you create a Bolt Circle Centerline then the position of that Bolt circle (center point of circle) and the radius of that Bolt circle is fixed. When the position of a circle changes the Bolt Circle Centerline ignores that circle and gives the "Invalid Radius" alert message when trying to add that circle to Bolt Circle Centerline
Anthony Galante
They should try designing a preliminary part that is constanlty changing due changing requirements = what happens in the real world and see how they like redoing bolt circles and centermarks over and over and over again. Kinda funny cause I never had this problem with NX 2 or 4.
