Looking for functions about Fig-G, CS-1 and CS-2 (ASME IID)
I want to make an application for fast finding Factor A&B in ASME IID.
So, I need the functions about Fig-G, CS-1 and CS-2.
Does any one know where can I find them?
Thank you!
http ://files.e ngineering .com/getfi le.aspx?fo lder=29ef8 a4e-db0c-4 cb6-a233-0 46510c3627 a&file =Fig-G.PNG
FIG. G GEOMETRIC CHART FOR COMPONENTS UNDER EXTERNAL OR COMPRESSIVE LOADINGS (FOR ALL MATERIALS)
htt p://files. engineerin g.com/getf ile.aspx?f older=bbab 679a-771c- 4905-a8d9- 1a88b8f4ff ed&fil e=CS-1.PNG
FIG. CS-1 CHART FOR DETERMINING SHELL THICKNESS OF COMPONENTS UNDER EXTERNAL PRESSURE DEVELOPED FOR CARBON OR LOW ALLOY STEELS WITH SPECIFIED MINIMUM YIELD STRENGTH LESS THAN 207 MPa
htt p://files. engineerin g.com/getf ile.aspx?f older=7808 14f4-79f7- 4b12-afb2- 1f004d85d8 99&fil e=CS-2.PNG
FIG. CS-2 CHART FOR DETERMINING SHELL THICKNESS OF COMPONENTS UNDER EXTERNAL PRESSURE DEVELOPED FOR CARBON OR LOW ALLOY STEELS WITH SPECIFIED MINIMUM YIELD
Thank you!
http
htt
htt
RE: Looking for functions about Fig-G, CS-1 and CS-2 (ASME IID)
Mike
