Modelling Filter Bypass Valve Pressure Drop
I am trying to model the pressure drop across an oil filter past the cracking pressure. Attached is a chart provided by the manufacturer when the cracking pressure is 90 psi. Since I am focused on the steady state pressure drop at a given flow rate, my intent is to isolate the linear portion of the plot and create a best-fit curve and use the y-intercept as the effective cracking pressure. Is this a reasonable method?
RE: Modelling Filter Bypass Valve Pressure Drop
But when the cracking pressure is 45 psi for another filter in the same series, I am not as comfortable to just assume a cracking pressure interval of 69 psi without soliciting feedback.
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
